Tighten clutch bolts
Fxr84
Post by Fxr84 »
Best way “stay” clutch from slipping while torque spring bolts
Re: Tighten clutch bolts
They only get torqued to 78 in/lbs (I assume an H/220 since nothing was mentioned about what bike you have) If the engine is in the frame put it in gear and block the rear wheel.
Fxr84
Post by Fxr84 »
Thank you
