needle for 01 kdx 200
- Country: Norway
hello guys, is the R1173K/2AFKP LEANER trough the rev range than the stock needle? (2001Kdx 200)thanks
KDX 200, 2001 model
The stock needle for the 200, R1174K, has a straight taper section larger than the R1173K so, no, it would be richer. Here's a handy little guide for decoding and determining which way you need to go: http://www.dirtrider.net/justkdx/jetneedles.html
- Country: Norway
Re: needle for 01 kdx 200
ok so what needle do most h series 200 guys switch too? since the stock bike is a bit rich on pilot, main,needle
KDX 200, 2001 model
The CEL needle I just installed made the pilot richer and its already a 38, 3 turns out, 35 maybe
. This needle (on 2nd clip) noticeably helped the midrange. Top end seems the same though dropped from a 155 to 152.
3200' elev., stock pipe, airbox top cut, power reeds.
