About to Start
- jstcraig
- Country: Australia
About to Start
A while ago a long while ago I joined the forum, recently I was ready to sell the 200Sr, so I drag it out and placed an add and had some good response, but the more I thought about it the less my desire to move her on. So let’s get down to the questions
Cooling System - tips for filling it up, it’s been dry for years.
Frozen Petcock - I believed the tank was drained but it looks like the tap was turned off and the carb was drained, would it be advisable to remove the tap and run it through a hydrosonic cleaner ?
Cheers for any and all comments ans advice.
- jstcraig
Re: About to Start
Re: About to Start
Hello. Welcome back.
I would try straight distilled water for right now. If it cranks and runs, then worry about proper distilled water and coolant combo.
I see the tank is metal. In the USA, we just had the plastic version. Ours have an o-ring or two that could be checked out. There is also a screen in ours that needs to be checked when the petcock is taken out.
Check for rust in the tank.
- jstcraig
Re: About to Start
Jason wrote:Hello. Welcome back.
Hi Jason how’s things,I like the idea of plastic tank this one sounds like a money box with a couple of coins in it , I will keep flushing it and dump ranex in and then tank cream it, the petcock is out and stripped none of the large seals have survived but at least it isn’t frozen any more, oops I should have used distilled but it will only took about maybe 2 litres and I will drain again in a couple of days just waiting to see if it loses any, have to remove and clean the carb and replace the inlet and filters. [emoji1303][emoji1303]
- jstcraig
Re: About to Start
Hey Jason if ur scanning, do you have or know where a pic of the US. tank for the 200e might be found, I’am want to assume but have no choice as a parts search for tanks and petcock doesn’t look anything like what is on this AUS. model. ??jstcraig wrote:Jason wrote:Hello. Welcome back.
Re: About to Start
Just look on Google images. There are a ton of E model tank pics on there. Just use 1989, 1990, etc. And fuel tank or gas tank to see a ton.
No F or G in the USA, just E, off road only.
- jstcraig
Re: About to Start
Part 1
Well the Carby was frozen solid and I started with a lever under the slide jst so I could remove the throttle cable. An hour and a half later the ultrasonic cleaner has started to work it’s magic and I have it completely dismantled and ready for the last clean. Wish me luck I want to have this running by the end of the month but no pressure lol
- jstcraig
Re: About to Start
I couldn’t resist putting this up, I think I need a new air filter, this has left me to [emoji848] what air filter do the forum members run .
Re: About to Start
I don't know if they make one for an SR, but I have had good success with Twin Air.
- jstcraig
Re: About to Start
I’ve found a stock one online, although I was considering a pod style and an air box mod, I want to keep the air box as I have had issue with removing them with some road bikesJason wrote:I don't know if they make one for an SR, but I have had good success with Twin Air.
- jstcraig
Re: About to Start
Considered that this post should be in the SR area is it possible to move it ??jstcraig wrote:I’ve found a stock one online, although I was considering a pod style and an air box mod, I want to keep the air box as I have had issue with removing them with some road bikesJason wrote:I don't know if they make one for an SR, but I have had good success with Twin Air.
Re: About to Start
jstcraig wrote:Considered that this post should be in the SR area is it possible to move it ??jstcraig wrote:I’ve found a stock one online, although I was considering a pod style and an air box mod, I want to keep the air box as I have had issue with removing them with some road bikesJason wrote:I don't know if they make one for an SR, but I have had good success with Twin Air.
- jstcraig
About to Start
Woohoo I jst nabbed the last kdx200f PE28 inlet manifold in Oz, really got lucky after being told it was out with the Dinosaurs
The latest image highlights the obvious difference between Sr and E manifold, I have an E manifold on the way will be good to be able to do side by side comparison.
Check out the date on the second image I think this was jst waiting for me to ask for it [emoji38]
- jstcraig
Re: About to Start
Well all the carby parts and new filter are here and once I rectify my rookie mistake in jet cleaning I can reassemble so fingers crossed. So I have spark hopefully fuel tank will be finished with restoration next week- fuel and yeehaa
- jstcraig
About to Start
122 Main
45 Pilot
Needle N68K
Would have a bent clue where to set the needle height how does three from the top sound ??
No I didn’t see where it was before I started, had to use a lever to move the slide when I started lol
45 Pilot
Needle N68K
- jstcraig
Re: About to Start
Another Positive
Drain the transmission last night and was pleasantly surprised that only old oil came out no water, so fingers crossed when it’s running the water pump seals will hold.
- jstcraig
Re: About to Start
Update
Oil injection is in hold due to parts availability and a weep hole in the oil reservoir tank
Re: About to Start
The oil tanks have weep holes??
- jstcraig
Re: About to Start
Are you saying the tanks are suppose to have weep holes ???Jason wrote:The oil tanks have weep holes??
Anyway this oil tank sits so close to the top of the pipe the heat has degraded the nylon and it weeps oil which runs down the hose . I'm wondering if the exhaust has been buckled causing it to sit so close ??. It's an easy fix remove the tank and block the hoses till I repair the tank and get a new check valve but maybe I've got it all wrong.
Sent from my iPad using Tapatalk
Re: About to Start
OK, it has a leak, not any weep hole. Thanks.
Without seeing one, I would assume yours is just damaged. How much did you pay for this smooth ride anyway?
