Needle Jet
Discussion specific to the 1991 - 1994 KDX250 sold in the USA
Terryankees
Needle Jet
Post by Terryankees »
Can anyone tell me were I can get a R1367 needle jet.or what would be a replacement for that?
Re: Needle Jet
You're missing a digit on your needle number that indicates L1 (should be like R1367J for example) The R just means a N427-48 series needle, 13 is the taper which equates to an option C and 67 is the diameter which equates to option H. So a N427-48CxH needle would be the same, with the x being replaced by the L1 code (most common for the KDX is an H IIRC). A N427-48CCH will be slightly richer than a R1367H and a N427-48CGH will be slightly leaner than a R1367H. Jets R Us carries them for about $7.
