Clutch kx125 89 in kdx
Jasper
Country: Belgium
Post by Jasper »
Will a kx125 89 kit fit in a e series kdx?
I thought i read it somewhere ... It is a rk013 kit
Jasper
Country: Belgium
Re: Clutch kx125 89 in kdx
Post by Jasper »
On the prox site the clutch plates have the same nr but the clutch kit not
More, less or other springs... Or different metal plates?
Timtee
Post by Timtee »
Why not just the correct clutch kit?
Jasper
Country: Belgium
Post by Jasper »
Because I can buy a kit for 40€
What brand is it??
Jasper
Country: Belgium
Post by Jasper »
Premier
For one of the plates, OEM is the same for one kind of plate, but not the other. It has a different part number. You may want to call or e-mail Premier.
Timtee
Post by Timtee »
Jasper wrote:Because I can buy a kit for 40€
How much is the one for the KDX?
Jasper
Country: Belgium
Post by Jasper »
90€
But it will not fit in need the rk061 kit
sarrant
Post by sarrant »
I think they do interchange. As I recall the difference was the KDX, had heavier metal plates and stiffer springs, so the much more common swap was to use KDX plates in the 125 for more durability and a little more rotational mass.
Jasper
Country: Belgium
Post by Jasper »
The clutch plates are the same but the kits not, so there must be a difference in metal plates and/or springs
My clutch is on the end but I'm not going to gamble with a "maybe will fit clutch kit"
What is the result when I would install the kx kit so what is the result with less heavier plates and weaker springs?
Generally with lighter springs the clutch lever pull will be easier (maybe not noticeable though) and the clutch could have a tendency to slip under a load. Lighter plates means less retational mass so possibly a slightly faster re I guess bike (with clutch engaged). Again, how much you would actually notice this is questionable. The possibility of the clutch slipping would be my major concern.
Note I am basing my comments on building out a 175 to a 230cc many years ago and the problems we had with clutches then. We never satisfactorily solved the slipping problem hence the engine never put the power to the ground it was capable of making.
