Julien D wrote:If it smells and feels like fairly clean premix, it's probably coming from the LH crank seal. If it's wet and gunky and slightly oily, that could be a gasket or wire grommet. I don't see any water in that pic.
Yep, it was fresh mix - in fact when I first took the cover off there was about 2-3 times more liquid in there but in the few minutes it took to find my camera, most of the petrol had evaporated.
Just waiting on a magneto puller so I can get a visual check on the seal - wouldn't you know, the puller I've had in my workshop drawer for the past hundred years is a rh thread !!
Tbh I'm expecting the worst, so I guess that means new crank seals then - not the end of the world though as I have quite good workshop facilities and now that I've retired I even have time to do it
Dan
