Soak Clutch Disks in ATF?
bergilong
Post by bergilong »
The '95 KDX200 needs a new clutch. I know you're supposed to soak clutch disks in oil overnight before you install them, but I run ATF type F in my bike. So, my question is, do I need to soak them in ATF overnight or should I just soak them in normal motor oil? Thanks for your time.
Sent from my ONE A2005 using Tapatalk
Re: Soak Clutch Disks in ATF?
Post by John_S »
ATF
Always soak them in the type of oil you plan to run which, in your case, that would be ATF.
bergilong
Post by bergilong »
Okay, thanks guys
