I just finished rebuilding my motor, put it in the bike and started hooking everything up. When I connected the clutch cable, I noticed I could pull the lever to the bars and could only feel slight resistance at the very end of the pull. I looked down at the lever arm and compared it to the one on my hybrid. It can rotate too far forward before you can feel resistance on it.
I am thinking this has to be something in the clutch stack up, like it needs to come out towards the right side of the bike more so that the advancer (13235) can push in the rod (13114) into the clutch more. I remember putting in both of the 92200 washers in on either side 92028
Before I called it quits for the night, I pulled the clutch cover and verified that the 92022A washer is in there (however, the diagram makes this washer's O.D. looks like it is larger than the actual washer). Can you think of anything else that I should be checking? I didn't change any clutch plates or springs or anything, and I wasn't experiencing any clutch issues before the rebuild.
- KDX Clutch Assy.JPG (38.48 KiB) Viewed 4833 times
