carberator
garycrafton
Country: UNITED STATES
carberator
Post by garycrafton »
IF I put a 200 carb on my 220 think it will run better ?/ being they are bigger and all
Has thanked: 66 times
Been thanked: 20 times
Re: carberator
MOVED to the KDX General Q&A instead of ask the moderator.
Willbilly
carberator
Post by Willbilly »
garycrafton wrote:IF I put a 200 carb on my 220 think it will run better ?/ being they are bigger and all
I guess the question is, what do you want to gain? Better is subjective.
javjacob
Re: carberator
Post by javjacob »
It will help the top end and over rev which the 220 with the 33mm carb have none of. Best bet is to send the carb to RB to get bored and everything.
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
garycrafton
carberator
looking for more power ,,my bike craps out at high rpm range ,,cleaned carb ,checked reeds,,throttle response is slow and sluggish ,,any ideas ?
Re: carberator
KIPS functioning well?
garycrafton
Re: carberator
Jason wrote:KIPS functioning well?
I do not think so ,,kips system is new waters for me
Re: carberator
The 220 is going to drop off on the top end more than the 200, but if your response is slow and sluggish run through the jetting guide. After making sure everything is mechanically sound. My 220 has no work done to it and pulls hard from bottom to top. THe RB carb work is also a good choice and will help the 220 breathe a little easier.
garycrafton
Re: carberator
sent gthe head in for kips rebuild and cleaning
cornishwrecker220
carberator
Post by cornishwrecker220 »
The 35mm carb off the 200 kdx will work on the 220..... You will need to use the 220s needle & slide in the 35mm carb & jet to suit ( 40 pilot & 152 main to start ) ...
The 220 will always fall flat towards the higher rev range compared to the 200 due to its porting , however you can retard the timing slightly which in turn will help the motor to rev out a little more.
commanderjjones
carberator
Post by commanderjjones »
cornishwrecker220 wrote:........however you can retard the timing slightly which in turn will help the motor to rev out a little more.
I was thinking about doing the same thing. Is there a down side to this? I assume that it's gonna lose a little on the bottom end?
So if I'm looking at the 3 timing marks, retarding it would be turning it counter-clockwise, correct?
garycrafton
Re: carberator
yes had it all rebuilt
garycrafton
Re: carberator
I have a #50 mail jet what pilot jet should I use ? seems to be cutting out until I really get the rpm's up /
Re: carberator
mail jet???
garycrafton
Re: carberator
Jason wrote:50
mail jet???
sorry main jet
Re: carberator
maybe one hundred fifty??
