compression test is reading the top end only. Remember, during compression, the combustion chamber is sealed off from the crankcase by the ring seal. You'd need to do a leakdown test to check for a leak in the bottom end.SmokingGreen wrote: if there were a hole in the crank case it wouldn't have compression, I put a psi test and its perfect so no holes.
