I am wanting to find a rear wheel for my 2000 KDX220 so I can put a paddle tire on it to have for the sand dune trips. It apprears to be nearly impossible to find a KDX rear wheel but I have heard certain year KX 125/250 and KX500 rear wheels also work. From what searches I have read 1990-1996 KX125/250/500 but also read that 97-02 KX125/250 work? I would also assume the KX500 didn't change so would a 1990-2004 rear wheel be the same on the KX500?
I Never would have thought it would be so hard to find a rear wheel. They also seem to be worth their weight in gold. Looks like $150-$200 is normal.
I have a wheel compatibility post somewhere on here....
If the wheel, actually it's the hub, fits an E series, it fits an H. On some KX hubs, you MUST change the wheel bearings to fit them properly, as some KX hubs have a larger axle. Meh, you should be changing the bearings anyway..
Sent from my KIW-L24 using Tapatalk
On, found it.....
All these hubs fit, the rims on KDXs are 18" and on KXs 19"..if that matters to you;
90-94 KDX (as tested by me), 91 on KDX 250s, a few older KX 125/250/500 90-96, KLX 650 93-96 and klx250/300 91-07.
Jason wrote:Worth their weight in gold? Have you priced a new wheel??
1990 - 2002 KX125 / KX250, 1990 - 2004 KX500 will fit the same, but I only know it will work on the 1989 - 1994 USA KDX200 models.
The money a new rear wheel cost is enough to buy another running KDX. Its crazy a wheel cost that much and even used ones of Ebay with missing spokes and cracked/bent rims still want a lot for them. I figure around $150 looks like a fair price for a good condition rear wheel.
Thanks for the info. I take it the KX went to a larger axle in 97? If they just need KDX bearings/seals that's not a big deal. I am just wanting a spare rear wheel to put a paddle tire on for the sand dunes.
I think they went to a 3 bearing setup in 97...not sure. The wheels posted fit, even some zuke wheels will fit with a bearing swap, but proceed at your own risk if its not listed.
