2nd gear screech
kiske
2nd gear screech
Post by kiske »
I have a KDX200SR
If I ride around the street or on flat dirt roads, there is no issues. However, once I put the bike under stress in 2nd gear, there's a nasty screech. I can force the sounds by attempting to pull off in 2nd with high revs.
I find the bike can't pull up a hill in 2nd also, but 1st and 3rd are fine.
Any ideas?
2nd gear screech
That doesn't sound good. If the SR trans is the same as the E-series then the 2nd gear on the output shaft rides on a bushing. The only way I can think of that gear screaching is that bushing is not rotating somehow. Sadly, the only way to check it would be to split the cases.
MaverickAus
Country: Australia
Re: 2nd gear screech
Post by MaverickAus »
Before you do that check your clutch
kiske
2nd gear screech
Post by kiske »
Going to swap out the gears as a friend has a spare engine I can butcher.
Thanks for the help.
TUrbano
Post by TUrbano »
I have same issue. What did you find when you openned her up?
Post by kdxsully »
This post is from 2017. You may not get a response. I would do as what the other members suggested. Check the clutch, then crack the oyster
