kx 125 trans in kdx
kx 125 trans in kdx
Anybody put kx trans in kdx? If so thoughts? I'm curious about a close ratio trans on kdx for woods and track. I can climb any hill in 1st on my kdx 200 and 6th gear is nearly unusable. I'd rather have 1st gear be like granny gear and 2nd and 3rd get me around without having to switch too much.
- Country: Australia
Re: kx 125 trans in kdx
Already have 1 tooth bigger in rear. Not that 1 tooth on rear makes a difference. More so lookin for gear overlap instead of either bein in right or wrong gear. I also have air atriker carb which took away some length in each gear
kx 125 trans in kdx
1 tooth bigger in the front did me great on my 220 keeps up with every bike on race day.
I struggled with 2nd being too low and now it's great. I mostly ride 3rd gear with occasional 2nd and 4th
- 6 Riders
I'm with the 14 tooth front sprocket. Seems to me that it helped with the big gap in the transmission.
Sent from my KIW-L24 using Tapatalk
- K50X200
kx 125 trans in kdx
Try a 12T sprocket up front... I've been running one for a couple years, and for me it works just about as you've described!muddymike wrote: I'd rather have 1st gear be like granny gear and 2nd and 3rd get me around without having to switch too much.
"00 KDX200 - Baja Designs D/S Kit, '03 KLX300 Forks, KB5 Suspension Mods, Keihn 35 ASQV, Boyesen Rad Valve, Gnarly Woods Pipe
kx 125 trans in kdx
To really answer your question, first and foremost you need to check the fit. I know of no one that that has done what you propose, so you will have to learn how the KX shafts and gears fit into the KDX cases. Maybe a friendly KX owner can help.
If you find the shafts and gears fit, and the shift forks and their rods also fit and everything functions, you can use the whole KX gear set, or crunch the numbers to see what ratios you can come up with.
Back in the 4 speed box days, there was one bike where we had a choice between using wide ratio road gears, which gave a bottom gear reduction of 3.3, and close ratio gears, which gave a bottom gear reduction of 2.42. Using a combination of of the 2, one guy crunched the numbers and found by using a lay shaft and main drive gear from the opposite set, (I forget the exact details now) he arrived at a 2.9 bottom gear ratio.
This is an interesting project, and may allow you to come up with a set of ratios that best suit your needs.
I hope this information is helpful. If you are successful with getting different transmission gear ratios, let us know.
Good luck.
Good luck.
When you researched bearing inner diameters between models, what did you see?
You did check that out first, correct??
Ya I saw what your talking about when I researched it. But just to make sure we're talking about the same thing, what did you see?Jason wrote:When you researched bearing inner diameters between models, what did you see?
For 2000, different left output shaft bearing ID.
I know that on some of the 90's KX250s, one can replace individual parts / pairs?? to get a lower first hear from a 98. Also, swapping in KDX250 gears into KX250.
Like another member said, I have never read of it being done.
Ya. Truthfully, me neither. That's why I asked (I googled 1st with no results then figured I'd check here). I'm familiar with people swapping years on kx 250 (I have a 2000 kx and people swap out the input shaft for '98 for lower 1st) and swapping kx 250 trans with kdx 250 trans (it takes trans and forks). So just wanted to see what info I could get, looks like we've come to the outcome. It's way cheaper and easier to just deal with the kdx trans. Any issue I have with the wide ratio would probly just be matched with a different issue on a close ratio trans.Jason wrote:For 2000, different left output shaft bearing ID.
