hi all i got the above to replace it.
but i thought it would be in the slide assembly but cant see it.
is it located in the carb bowl area .?
ran out of time last night
Just seen the pic posted in my other thread.
presumably it is accessed by removing the bowl?
what size Torx fitting?
So i can mod one at work today ready to use tonight.
thanks mark
jet block gasket location ? kdx200 H
- two-stroke-brit
- Tyl3r
Re: jet block gasket location ? kdx200 H
Remove the carb bowl and locate the block that the two jets thread into. It is secured to the carb body with 2 security torx screws. IIRC, those are the only two security torx fittings inside of there lol so if you find those, you'll be all set.
Can't recall the size of the torx bit I used. Do a search on here, I remember someone posting the size at one time.
