LINK TO SHARED ALBUM
https://goo.gl/photos/3NeP3VhM4Vz85iN79
So you can browse the pictures a little easier.
92 KDX KLX 300 Forks Swap
KDW
- Has thanked: 49 times
- Been thanked: 15 times
Re: 92 KDX KLX 300 Forks Swap
So, an E brake system with the KLX300 forks?
Good job!
Good job!
KDW
The calliper is from a KLX300. The E brake line and MC should work. Will update.
So, an early E wheel?
KDW
Yep
all that is needed for the swap is
Forks
Calliper
Axle (e spacer is even the same)
Fork Guards
As I said I am yet to bolt up the brake line but it looks like it will work just fine.
Forks
Calliper
Fork Guards
KDW
I will know when the guards get here but I might have to hack a chunk out for the brake disk. It is a good 3/16-1/4" closer to the fork leg than the stock 300 set up.
KDW
OK... results!
image by Kristoffer Welch, on Flickr
The brake hose routing works but you have to stick it out the side like the picture because of the stock hose fitting. Still better than the KLX300 routing IMO.
Just got it all done, I will post a summery of the process this weekend if I can find the time however I might be riding!
image by Kristoffer Welch, on FlickrThe brake hose routing works but you have to stick it out the side like the picture because of the stock hose fitting. Still better than the KLX300 routing IMO.
image by Kristoffer Welch, on FlickrJust got it all done, I will post a summery of the process this weekend if I can find the time however I might be riding!
Looking good!
Santa Cruz hand!
The forks do make the front end look a lot better.
Look on some 1987 - 1989 KX parts diagrams for better upper brake hose routing.
You might also read up a couple of guys here have a brake hose clamp mounting plate on their guards. It seems to work well for them.
Santa Cruz hand!
KDW
Yeah I just had the brake line tucked in there to keep it out of my way while I figured things out. I need to get another guide for the top. It does look allot better. Didn't get a chance to ride (well I did do some street riding) this weekend to test it. I will post once I get a chance to ride it. I live in the City so it's a bit of work just to get it out where I can ride it.
