Output shaft seal leak
I've replaced the ouput shaft seal, collar and 2 o rings twice. They're leaking like crazy. Anybody ever have this bad of luck and if so what did you do to fix it? Thanks in advance!
- doctord23
Re: Output shaft seal leak
It sounds like you have changed the sealing surfaces.
Check the breather tube and make sure that it is clear and not allowing pressure to build up.
Also clean the surrounding area and make sure that there is not a crack in the case. If a chain let loose at some point, that can damage the case.
Last thing to check would be a bad bearing on the output shaft.
Good luck.
Good luck.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
What circlip and what front sprocket?
And if you want to let us in on a secret like... WHICH KDX, that would be great too
