RAD MFG wheels?
whos that
RAD MFG wheels?
Post by whos that »
http://www.radmfg.com/RAD-Rear-Wheel-Ki ... 00250r.htm
Has anybody had experience with these? I have a broken rear hub on my 1996 and I do not know of anywhere else that makes aftermarket hubs for our bikes.
If anyone has a stock one in good shape, I have $$ ready
I could also use a service manual.
Thanks!
-Pat
ICRage42
RAD MFG wheels?
Post by ICRage42 »
Thats dam pricey and if your not sponsored or worry about your mashed tators count then its not needed.
I would just pick up a used rim off of ebay or see if someone has one here. Thats what I did. I broke my hub when removing bearing. I pulled the c clip but however a piece stuck in and rusted there. Drove bearing out with piece of hub. Hub was trashed and pretty much had to buy a whole tire for the hub.
Theres several here thats posted full kdx part outs that youll be able to find one here.
Most dont part out with a spare rear wheel. Most cases it gets a different tire mounted for other riding conditions. Winter riding with spikes etc.
If your not aggressively competing I would say its overkill and if you ever go to sell the kdx youll never get your money back for doing it.
RAD MFG wheels?
ICRage42 wrote:...I would just pick up a used rim off of ebay or see if someone has one here...
+1 You can find OEM rims on Ebay fairly cheap. You can use a 19" KX wheel (with the KDX spacers), or take the hub off a 19" KX and lace it to an 18" rim if you cant find a whole KDX wheel assembly
whos that
RAD MFG wheels?
Post by whos that »
Thanks guys, I appreciate the info.
Kdxkato
Country: Australia
Re: RAD MFG wheels?
Post by Kdxkato »
Does anyboby know if a kx 125 hub would fit a 96 kdx200. Looking to get new aftermarket and cant find a manufacturer
Re: RAD MFG wheels?
What year? Anything newer than mid 90s not without lots of work, the axles are different sizes (KX axles are larger in diameter).
Tyl3r
Re: RAD MFG wheels?
Post by Tyl3r »
I have an H-series hub in good shape if you are interested in it. I can send you pics after work. Shoot me a PM
