is the carb the same size on the 200 and 220
two-stroke-brit
Post by two-stroke-brit »
hi All. as above really sums it up.
T I A Mark
She might not be pretty but always a fun ride !
javjacob
Re: is the carb the same size on the 200 and 220
Post by javjacob »
The 200 is 35mm, the 220 is 33mm.
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
Willbilly
Post by Willbilly »
220 is the Keihin PWK 33 and the 200 is the Keihin PWK 35
Here's the manufacturers website with info.
http://www.keihin-na.com/aftermarket/pwk/
two-stroke-brit
Thanks .
that seems counter intuitive ?
the 220 having the smaller carb?
good info that.
although i read the spec for both carbs and it looks like they are the same size but jetted differently?
cheers mark
pumpguy
Post by pumpguy »
The 220 also has milder port timing. That, combined with a smaller carb results in better low to mid range performance. At least that's the theory behind the difference.
This also explains why different aftermarket exhaust pipes are recommended for the 220 vs the 200. Stock, both the 200 and 220 use the same exhaust.
Yeah, general rule of thumb is smaller carb for low end (torque), larger bore for top end (peak horsepower) (all other things being equal) and is why people always talk about the 220 being more of a tractor than the 200. Just basic physics, a smaller bore flows at a higher velocity than a larger bore. A really good explanation here. That is one reason for carb divider plates (as in the RB mod) as it decreases the effective bore at partial opening, increasing velocity for better torque/throttle response down low, but allowing larger volume at full opening.
two-stroke-brit
bufftester wrote:Yeah, general rule of thumb is smaller carb for low end (torque), larger bore for top end (peak horsepower) (all other things being equal) and is why people always talk about the 220 being more of a tractor than the 200. Just basic physics, a smaller bore flows at a higher velocity than a larger bore. A really good explanation here. That is one reason for carb divider plates (as in the RB mod) as it decreases the effective bore at partial opening, increasing velocity for better torque/throttle response down low, but allowing larger volume at full opening.
thanks buffy, i am saving my pennies for a bunch of RB upgrades.
cheers mark
