84 kdx200 stator mod... Now what?....
Googledave
Post by Googledave »
So my flywheel blew up and I got a newer flywheel and clocked the staotor(fredette mod) now what? How do I orient the stator on the motor? Thanks!
Jaguar
Country: Ecuador
Re: 84 kdx200 stator mod... Now what?....
Post by Jaguar »
"clocked the stator"?
post a photo
Googledave
Yes, I clocked the stator... I just don't know where to set it... The original timing you line up the mark on the stator to the mark on the case... Now with a clocked stator where do you set it? Is it just as simple as put it on there tighten bolts and that's it? Also, how do you post a pic? I tried but cannot get it to work thanks!
kawagumby
Post by kawagumby »
I did some research on this a while ago...see the post below (C model using a later flywheel) that has some pictures for C model flywheel changeover. The rotation is 90 degrees, based on the Fredette stator mod for the C model, I'm sure the '84 is the same.
nedrowjoe
Post by nedrowjoe »
I know it's an old thread. But I just came upon a 1986 kdx 200 for almost nothing. Its mine so no backing out. When you say rotate 90 degrees do you mean clockwise? Or counter clockwise, common sense tells me clockwise, but I don't want my stator plate to be more like Swiss cheese than neccesary
mwoj
Post by mwoj »
Also a dead thread. But how much you you guys be willing to pay for a used flywheel from a 1984 kdx200. In good condition
nedrowjoe
Post by nedrowjoe »
I would have to see if an 84 would work on mine. But I would be willing to pay what the going rate for the next gen flywheel are going for. Like 60 bucks.
nedrowjoe
Post by nedrowjoe »
The problem with a used 1984 flywheel is that those magnets could let loose at any time. Now if it was new old stock you could probably get hundreds for it.
mwoj
Post by mwoj »
True. theres this one guy on this site that refurbishes them. I might just send it to him to have it re done. Anyway if anyone REALLLY needs one jsut lmk
