head set pin removal
javjacob
Post by javjacob »
I pulled my carb and head so I can send them to RB to be worked over. RB says to remove the set pins on the head, I removed one without much trouble but the other one is stuck and I cant get it out. Is there a trick to getting it out?
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
Re: head set pin removal
Washer around it, pliers to pull it has worked for some
javjacob
Post by javjacob »
I will try it some more. I have tried needle nose vise grips and still haven't got it to budge.
pumpguy
Post by pumpguy »
You might try some heat around the pin, not on it. While it's hot, spray on some penetrating oil.
Good luck with this.
+1 heat and oil
