Choosing the right forks: Basic questions
taxonomy
Post by taxonomy »
I am thinking of doing a fork swap, but I would like to keep it simple. For me this means using the KDX wheel as 500 complete front ends seem hard to come by.
I think I am looking for 1999-2003 forks KX125 or 250 forks as I can retain my front wheel.
Will I need to have the forks shortened to retain stock geometry?
Am I overlooking some other forks that are easier to use?
Is there any difference internally in the forks from '99-'03
Is it worth getting newer forks or some other kind of fork rather than sticking with the 99-03?
I see a lot of listings for forks on eBay that say 99-02 which makes me wonder if the '03 for is different in some way?
Sorry about so many questions.
taxonomy wrote:I am thinking of doing a fork swap, but I would like to keep it simple. For me this means using the KDX wheel as 500 complete front ends seem hard to come by.
You had another post about possibly buying a 2006 KDX200, so I will go from that.
If you want to use a KDX wheel on a KX fork, you will need to have an axle made or adapters machined.
Several KX125 / KX250 front wheels will work on the KX500 forks.
"Will I need to have the forks shortened to retain stock geometry? "
On KX forks, yes, unless you pull them way up in the clamps and then deal with them possibly hitting the handlebars.
"Am I overlooking some other forks that are easier to use? "
Simplest is switching to a KLX300 / KLX250 / KDX250 clamps, forks, guards and necessary brake changes. The 1995+ KDX axle and wheel are used.
"Is there any difference internally in the forks from '99-'03"
Yes, bladders, bumpers, stock springs are proggressive / linear, OD tube diameter, etc.
"Is it worth getting newer forks or some other kind of fork rather than sticking with the 99-03? "
Let your budget, desire and riding level be a judge.
"I see a lot of listings for forks on eBay that say 99-02 which makes me wonder if the '03 for is different in some way? "
1999 - 2002 KX125 / KX250 are in the same model family. As far as forks, the top clamp is 99 - 01, bottom clamp is 98 - 01, 2002 is its own unique year. (Someone correct me if I am wrong)
DJNiedz
Post by DJNiedz »
will any year klx 250 front end work? I see klx 250 front ends all the way up to 2012 sometimes for sale.
Tyl3r
Re: Choosing the right forks: Basic questions
Post by Tyl3r »
Personally, I would go with kx forks over klx forks if you plan on a rebuild/revalve.
For the easiest, I did a 94 and up (if memory serves) KX500 swap on my old KDX. I didn't respring/valve them, but they were a massive improvement and I loved them. The swap couldn't have been easier. If you really need that stock odometer.... a Trail Tech computer can be installed for less 100 bucks and you get a lot more info.
Unless you are a serious racer, it's not going to make much a difference what year you go with, especially if you are on a budget. I'd just try to go with something from this century haha With a proper spring and valve job. It's going to be a big improvement over stock...that's my opinion, take it for what it's worth lol I'm only a weekend warrior
kdxron
Post by kdxron »
So will the KLX 250 forks/triple mount the same as the KLX 300? I'm on budget and don't want the buy new wheel/brakes. etc. Currently there is set of KLX 250 forks on ebay but no KLX 300 forks.
Thanks
