Has anyone had to have a broken frame welded ? our has broken on the right hand side where the stay from the rear guard welds to the main frame ( by the kick start) I will post a pick if I can figure out how to up load one, I guess I go to a panel repair shop and ask them to Mig weld it back together ?
I still can't seem to load the image but here's the photobucket link
That's weldable. For the record, when you look at that link on photobucket, to the right is a section that says "share this photo". If you copy the one that says "direct", and paste it into your post. Then highlight that and click the button above your post window that says "Img". That will wrap it in tags like this [ img ]http://i32.photobucket.com/albums/d27/c ... e8pa8u.jpg[ /img ]. I added the spaces so you can see what it should look like. I edited your post with that change. :)
