Noticed a lot of dirt around the shaft of the shock and very bouncy I pulled it apart and there was only a couple teaspoons of Grey slime left inside of it. Anyone know where I can find replacement Grey slime when I put it back together?
Old Yamaha de carBon monoshock
1990 KDX200FMF Fatty, Answer VFC silencer, VForce 3 Cage, Wiseco Piston, KX125-J series KYB USD fork conversion, Race tech goldvalves, J series front brake assembly, air-box snorkel removed, Acerbis Headlight, KX450F Front fender, Pro Taper RM bend bars, ASV front Brake lever, MSR Clutch perch and lever, RB Head mod, 36mm PWK carb, Trail Tech Kickstand.
The reservoir has no shader valve on these instead they use a self sealing/healing rubber valve that you are supposed to charge and de-charge through with a hollow needle like a syringe neelde. I decided to drill, tap, and install a 1/8"NPT shader valve for future service. Another option would be a 46mm racetech reservoir cap and kyb 46/103 bladder which is the route I will probably go in the future if the piston seal starts failing
david wrote:Man I bet that thing is going to be a beast! I've been on a couple of old open class motocross bikes (CR480, YZ490) but never a woods bike.
Should be very similar to the yz490 but with a 5 speed tranny instead of 4 speed im hopIng to have a very fast tractor when it's done
It did not appear to be modified. They have a tendency to ping when hot. I considered doing the head mod but I'm going to get her on the trails first and see how it runs.
I have a sneaking suspicion that I will not have the issue since I wont have the engine wound up all day long on the trails my thought is that the issue is more prevalent with the MXers, sand dune guys not so much the trail bikes but then again I have no evidence to back this up other than there being way more discussion about the head mod on the YZ490 than the IT490 this could also be due to a smaller following of the IT's.....
Looking good. You might want to look into joining the yz490 group. I think it's a Yahoo group, not sure but some members of a New England group I belong to said they are a great reference for theses bikes.
Dekon wrote:Looking good. You might want to look into joining the yz490 group. I think it's a Yahoo group, not sure but some members of a New England group I belong to said they are a great reference for theses bikes.
I have not come across that group yet. I am however a member of the yamaha IT forum they'very helped me some with dad''s IT200. I believe theyre based in Australia?
Links in case anyone else has any interest in the ITs
Forum: http://www.yamahait.com.au/forum/index.php
History http://www.yamahait.com.au
