Anyone ever tried E-series pipe on C-series ?
I searched and didn't find. Has anyone here ever even checked how far off an E-series pipe would be from fitting a c-series? It looks like the stinger on the E is pretty high and straight like the C. I don't have an E around to compare. I'm sure it can't be direct fit obviously but am wondering if it's even close. If all it would take is some minor tweaking and new tabs then it might be worth a shot. TIA!
scriberman
Think the barrel exits straight forward on E and to the left on a C. Single and double frame downtube.
- Has thanked: 10 times
- Been thanked: 17 times
Re: Anyone ever tried E-series pipe on C-series ?
^ I believe that is correct. Also the main portion of the pipe turns up farther and faster than it does on the water cooled bikes, because there was no radiator and shroud in the way.
