transmission drain plug gasket replacement
bws2
Post by bws2 »
I've got an '01 Kdx200 and have read that the drain plug washer/gasket should be
replaced when changing the transmission oil.
Is this something that you guys do? If so is there an aftermarket option or is OEM the way to go?
Thanks
kaw814
Post by kaw814 »
yes...if i dont replace the crush washer it leaks at the drainplug
Re: transmission drain plug gasket replacement
I think it would be OK to use aftermarket, but have no clue where one could find an exact match. I imagine that by the time one spends time and money trying to find an aftermarket one, it may have been easier and maybe even cheaper in total cost (time, hassle and money) to get an OEM one.
Sullyfam
Post by Sullyfam »
I bought a box of aluminum crush washers at Cycle Gear in a pinch and have been using them on all my bikes with no issue. You might even be able something at an auto parts store. No magic to them but size and material (copper or aluminum)
canamfan
Post by canamfan »
I've never replaced mine and it doesn't leak. Don't overtighten either. If I have trouble with a drain plug leaking or feel the threads are getting worn I'll wrap it in thread tape.
C George
Post by C George »
John Deere M 806438 are 12mm rubber sealing washers which work great.
They only require a light tightening due to the rubber seal.
Far cheaper " a few bucks " locally , than some of the ridiculous prices on line.
https://s3.amazonaws.com/cdn.hartvillet ... _thumb.png
Otherwise : plenty of " aluminum " 12mm sealing washers can be found on line.
Silverfox
Post by Silverfox »
Never replaced mine either, and no leaks.
newbbewb
Post by newbbewb »
Brake line copper washers work also. I rarely replace my gaskets and don't have issues. Use a bit of grey or black rtv if you don't have washer.
93 kdx200-Highly modified
89 kx125/kdx200E engine
Buelldustin@gmail.com
G22inSC
Post by G22inSC »
C George wrote:John Deere M 806438 are 12mm rubber sealing washers which work great.
Never would have thought of that one.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
pumpguy
Post by pumpguy »
Don't just go to the hardware store and try any old rubber washer that looks like it might fit.
Rubber compound needs to be Buna, Viton, or something that is compatible with petroleum products.
Neoprene is most common hardware store available rubber material, and it is NOT compatible with petroleum products.
C George
Post by C George »
I actually stand corrected ,,, the drain plug is 10mm , not the 12 as stated.
Surprised you guys didn't correct me :)
