Kdx220r rear spring swap Q
Sportbikeco
Post by Sportbikeco »
I need to get stronger springs on my new to me kdx220r.
What bike would provide a rear spring around the 6.0kg/mm rate that would swap in to my KDX that I can score at the bike junk yard or eBay?
Has thanked: 5 times
Re: Kdx220r rear spring swap Q
Does anyone know if a KLX300 spring will work? It is apparently 5.8.
Are you sure you need a 6.0?
Sportbikeco
Ya racetech is saying 6.0-6.2 range, im pretty big.
Sportbikeco
still looking anyone have a recommendation?
ewhitelaw
Post by ewhitelaw »
I've got a spring that's too strong for my weight (165#) but don't know the exact spring rate. Do you know the rate on your currect spring and what's your weight?
According to racetech.com spring rate calculator for my weight, I need a 4.6kg/mm spring. Stock on the 220R is 5kg/mm/
You are 165 in full gear?
Sportbikeco
Hope it helps somone, i found out a KLX300 spring swaps in through looking at racetechs part #'s and the KLX300 spring is a 5.8 stock, bought a used one on ebay for $20.
cornishwrecker220
Post by cornishwrecker220 »
You can try & turn down the spring adjuster nut 2 or 3 turns to stiffen the spring & turn the rebound in on the bottom of the shock 1 or 2 clicks & go from there....I'm around 98kg & it works for me
Thanks, sportbikeco.
cornish, what sag numbers would that cause?? :hmm: :hmm: :hmm:
cornishwrecker220
My bike still has around 1.5/. 2" inch free sag from off the stand even with me sat on the bike it only goes down another inch ...I only trail ride & it works fine .
The kdx spring is ok for light to medium weight riders but a few extra turns I the spring doesn't really hurt for non competition work.
You can try it for yourself , if you're not happy then it's simple to put back.
The key is to remember is to go 1 click or 2 clicks in on the rebound to slow the kick back from the extra spring force.
