n00b Jetting Questions
A reference for the PWK carbs...
jack_ellis
Post by jack_ellis »
Hi Guys, what a great forum!
Here's whats up:
I have a 1998 KDX200 which needs quite a bit of work. It's running but I'm sure it could be better.
I have currently a 48 Pilot and a Main jet 160
Needle on the 3rd position
I'm riding in Wales UK . 116m above sea level.
The problem i'm getting is a crappy top end. at higher revs just poops out. It's fine for working under 15mph but as soon as you want to get a bit faster it's not great.
I set the air mix screw at exactly 4 turns out. I set it like that because the engine revs were highest at that point when idling. Was that the right method? That's how I've set my 4 stroke road bikes before.
Spooging too.
Do those jets seem a good start point you reckon?
Has thanked: 10 times
Been thanked: 17 times
Re: n00b Jetting Questions
Tuning the airscrew out to highest idle is just to determine if the size of your pilot is appropriate. 4 turns would indicate that you need a leaner pilot. After that the airscrew needs to be adjusted for best off-idle response, not fastest idle speed. 160 is probably large on the main, as well. The only way to get it dead on is to follow the jetting guide.
http://www.kdxrider.net/forums/viewtopi ... 105&t=1156
canamfan
Post by canamfan »
You sound rich, Over here in the usa runnin about 145 main, 40 or 42 pilot around 500 ft above sea level.
Jaguar
Country: Ecuador
Post by Jaguar »
check engine compression and that the crank seals aren't leaking.
change the spark plug also.
clean the air filter.
make sure the silencer isn't clogged up.
cornishwrecker220
Post by cornishwrecker220 »
Mix a fresh batch of fuel & oil ( 40.1 ) & a clean & oiled air filter along with a new spark plug.
Pilot jet ...42-45
Main jet ...152-155
Needle in the 3rd position or 2nd
Air screw ...1.5- 2 turns out
If you are not running the air box lid then the main jet may need to be increased to 155-158 if you use a lot of full throttle !
jack_ellis
Brill, I wish I could try it out now! I have just ordered a few jets on your guys suggestion. will try them out and see what happens after resetting the air mix.
Fresh plug just in, air filter replaced and re-oiled
Reeds? can these mess up and give those kind of symptoms? it's on my to-check list
The airbox as far as I know is standard and un-modified.
Many thanks,
Jack
