Help from Russia)
russian
Help from Russia)
Post by russian »
Hello,
i have a kdx250sr, but i'm not sure what is the engine inside. Now i disassemble my engine and see 2 bearings in bottom end, that have no any crank on them. I don't know how to attach a photo here.
It has no oil pump on my engine and 3 power valves in cylinder (like on 250r version). But maybe bottom end of the engine from 250sr and the top from R version?
So my questions: what was the shaft through all the crankcase, that no need now?) And what the engine i have)
Sorry for my bad english.
Re: Help from Russia)
engine number?
russian
Post by russian »
i don't see any numbers on engine cover
If you take photos and upload them somewhere like photobucket or imageshack, then you can link them here.
russian
Post by russian »
Thanks,
i download picture on photobucket http://i1055.photobucket.com/albums/s52 ... sxundx.jpg
It's not the photo of my engine, but it's the same. I mark there bearing that have no any shaft inside. And the such bearing on the left side of engine near magneto
We will have to have an SR owner chime in. That bearing does not exist on the US model KDX.
russian
Post by russian »
And there is no gear on the top for fuel pump and this window under it on US version, isn't it?
russian
Post by russian »
sorry not fuel - oil pump
Jim B
Post by Jim B »
Have you checked the parts fiche/diagram? Most dealers, at least here in the U.S., have them on their websites.
russian wrote:And there is no gear on the top for fuel pump and this window under it on US version, isn't it?
Correct. the US model does not have the cutaway from the case or that top gear for the oil pump.
russian
Post by russian »
bThanks for all. I find that i have an engine with 250sr bottom and 250r top. So this bearings are place for electric starter.
Jim B
Post by Jim B »
Good luck with your project. :grin:
Kurt123
Country: UK
Help from Russia)
Post by Kurt123 »
Hi,
I believe it is a balance shaft for vibration, on my SR the shaft this side of the engine has teeth where your pink arrow is, which mesh together with the primary gear (i think!), on the other side of the shaft it has a weight the other side of the engine near the magneto.
The oil pump is fitted where that circular hole is towards the top left of the photo :grin:
The KDX250 manual doesn't mention these SR differences unfortunately such as the oil pump, balance shaft etc :cry:
Help from Russia)
My guess was a balance shaft also.
