Been reading a lot, but can't get clear info. Hoping to put it all together in one thread.
Please give your opinion of both of these options. I have read the pro/carbon fiber are better performing, but don't last as long. Any truth to that? How long do they last?
For the uninformed and for sake of future searches, these are both dual stage reeds made by Boyesen, that replace your stock reeds, using the standard stock cage. The Pro Series uses carbon fiber and the Power uses fiberglass.
As always, thanks to all for sharing your knowledge and experience.
Boyesen Pro series reeds (dual stage) OR Power reeds 607 (du
- 19Delta
- 19Delta
Re: Boyesen Pro series reeds (dual stage) OR Power reeds 607
Any particular reason?BlackMist wrote:607's are your best bet
- Tedh98
If I am recalling correctly, you have two KDXs and you already have ordered the carbon reeds. That puts you in the desireable position of being able to directly compare the two. Within minutes you can swap the reed blocks and compare them on the same bike, same day, same trails, etc.
You cant go wrong with the 607s - they perform well, last as long or longer than anything out there and are reasonably priced.
