Mechanical seal help!
waldo177
Post by waldo177 »
What are some proven methods of installing this mechanical water pump seal? I just broke the new one and will be ordering another, maybe 2 just in case. Please help
Sent from my SM-S920L using Tapatalk
bone7615
Re: Mechanical seal help!
Post by bone7615 »
I'm not sure if this is what your looking for but I hope it helps.
If you had a choice to date supermodels for the rest of your life or ride dirt bikes, would you choose a 2-stroke or a 4-stroke?
waldo177
Post by waldo177 »
That's how I broke the new seal the first time, maybe I need to search for a different socket like a thin wall because the bigger socket I have will not fit down in the tight spot to get it seated
david
Country: UNITED STATES
Post by david »
You don't want to push on the carbon or the ceramic pieces with anything hard and you have to use steady, even pressure. No shock loads. We have seals like that for 2.5" and 3.0" shafts here at work that cost up to $1500. Gota be real careful putting them in. I would see if you can find a small piece of PVC pipe or plastic tube that you could use as a 'push stick', not a metal socket.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
waldo177
Post by waldo177 »
Thanks I will try that good idea. If I can find some that will slide over the ceramic end to be able to get to the metal cup
david
Post by david »
You definitely only want to press on the metal cup, NOT on the carbon element, those are SUPER brittle.
'81 KDX 175
'90 KDX 200
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
waldo177
Post by waldo177 »
That's what I thought I was doing but my socket I guess was touching more of the ceramic end than I thought. It's a very tight space on that cover to get into.
Ffryno13
Post by Ffryno13 »
Any luck on the install, im having the same issue right now. Also is there another oil seal between the mechanical seal and the sealed bearing?
Tedh98
Post by Tedh98 »
Ffryno13 wrote:Also is there another oil seal between the mechanical seal and the sealed bearing?
Yes. On an H series at least.
Ffryno13
Post by Ffryno13 »
OK so I found the oil seal behind the bearing. My next question is on the sealed bearing does the seal go to the oil or the water?
Tedh98
Post by Tedh98 »
Ffryno13 wrote:OK so I found the oil seal behind the bearing. My next question is on the sealed bearing does the seal go to the oil or the water?
I am assuming mine has never been replaced and the seal is to the water. I think that makes sense as the bearing would then have lubrication.
Ffryno13
Post by Ffryno13 »
That's what I was thinking but I thought I read somewhere that seal went to the oil, the sealed bearing does have grease in it....I'll have to flip that around... And since that is true I can assume the oil seal would have the flat side to the water.
waldo177
Post by waldo177 »
That is the way I installed the oil seal was the flat side towards the water. But I also pointed the sealed half of the bearing towards the water as well
Ffryno13
Post by Ffryno13 »
I found a peice of conduit at work that is pretty close to the right od/id of the mechanical seal so I can install the new one when it comes in next week... I hate waiting
