Just bought on Sunday a 1990 kdx200 e2 model. Has compression at 90 psi. Doesn't feel very powerful at all, this coming from a guy who rides an xr280 in the forest and occasional slow rocky desert.
Questions:
1. How much labor is involved in a top end? How many hrs, not counting having to send a cylinder out for plating, parts chasing, etc but including pulling the kips apart and replacing, cleaning, etc? I've done top ends on xr's, not too inept but haven't had a kips apart. Day job? How many hours if I was to contract it out to a reasonably skilled shop?
2. I figure if. I'm going to be in there,might as well do it right and do it once. Otherwise I'm not giving this two stroke thing a fair shake
I understand there are some cylinder or head mods and a special valve, reed kips or steel kips replacement doohickies that bring it up towards 36 hp? Also something called a "torque ring" which is essentially a fat washer between the head and the header pipe?
What I'm trying to get out ot the bike is a lighter, faster xr, low end torque as much as possible. Bike has an fmf woods header on it and a Powe core muffler, I understand I need the turbinator muffler with the spark arrestor for public lands, and probably should have all this in place b4 jetting so I don't waste my time. Can this bike be run Ata crawl on rocks and opened up for some 45-55 dashes or in some cases long desert roads without hurting it or am I asking too much of a two stroke? I'm getting mixed info from two stroke buddies.
3. Last wuestion, looks like the shock is leaking a bit of oil. Dunno how long it's. Een doing so, but seems a bit harsh on square bumps like curbs at 20 mph. Forks are kx and do ok. I weigh 190, seller was a 120 lbs woman. Has a blue spring on it, which I hear is stock. It's possible the shock is too low in its stroke, but I like the lower height.
Hoping to use this bike as a cross trainer on rocks, wheelie easier than a xr, so far not seeing it! It is CA plated, biggest draw.
Thanks,
Chuck
