This is the way I did it.
Bottom of page 26 from the signature link or bottom hear:
http://www.trials.com.au/forum/viewtopi ... 303#p37303
How to true a crank
- Tioli
- Country: Tasmania AUS
How to true a crank
How to true a crank
To answer your question about where to measure the runout, it depends on where you support the assembly.
You have it supported on V blocks where the bearings reside. Others support the crank assembly out at he ends with cone pointed steel centers fitting in the drilled dimples at each end.
When supported on V blocks like you did, as you say, the maximum run-out will be at the ends of the shafts. When supported between centers, the maximum runout will be where the shafts meet the wheels.
I expect the factory measures the runout between centers, and show runout dimensions where the bearings reside. If you ever see an old Harley factory type crank truing fixture, it will have hardened steel centers at each end, and runout indicator needles to ride on each of the bearing diameters.
- Tioli
How to true a crank
that's what confused me. As you say if you use cones on the ends measure in the middle and if you support in the middle measure the ends.
The manual clearly shows support in the middle and measure in the middle. A little out on the gear side but nowhere near as much as at the end of the flywheel shaft.
Seems like the tolerance in the manual is a lot more forgiving.
