Well the newest issue is that I've found a small crack above one of the plastics brass mounting insert.
Very small but still I find some gas coming out after it sits a while.
Looks like at some point someone put some JB Weld around the brass inserts on that side as well. They seem fine though.
Considering just going the JB Weld route for the crack as well.
Anyone have experience with this?
Hate to spend the money of a whole new tank just because of this little crack.
Crack in tank
Crack in tank
Yes plastic weld.
However, now that I've got to look at it more, it's actually coming from the opening of the lower brass insert you screw your plastics into.
- diymirage
Crack in tank
get yourself some caswell epoxy tank sealer
it is a two part epoxy used to seal porous tanks
-1997 KDX 220 project bike
Re: Crack in tank
What model do you have? I have an extra tank.
Crack in tank
Try that new UV cured plastic welding stuff they have been advertising on TV.
Crack in tank
It's a 2001 kdx220 bultaco4ever
