So now I basically need a new wheel... Although that's kinda ok because a few spokes were seized anyway.
Sent from my SM-N910V using Tapatalk
I think he charges around $200 with new #8 spokes (plus the rim). He hand cuts, bends and threads the spokes. You'll never have to worry about loose spokes again!rashad wrote:Any on idea on prices? I'd like to not have to assemble it if possible.
that's a bummer. put some pbblaster on the nipples every day for a week, then heat one side and pbblaster the other. they might release enough to true them up.rashad wrote:Silly me for assuming things. I bought two new tires and excitedly got ready to mount them...then noticed something...
rashad wrote:the funniest part of this... i just put new kdx rear bearings and snap ring in it... so the hubs must be identical. I thought they had some weird kx parts on this bike... so they must have put two bikes together. the rear axle was all wrong as well.
There are certain year KX hubs that swap, the rear hub in the picture above is a KX hub. Nice thing is you can score KX hubs (or whole wheels) for CHEAP (I recently bought two for $70 complete. One of them is pretty rusted together and will take time to disassemble....the other one was fine for just the hub, spokes where tossed.rashad wrote:the funniest part of this... i just put new kdx rear bearings and snap ring in it... so the hubs must be identical. I thought they had some weird kx parts on this bike... so they must have put two bikes together. the rear axle was all wrong as well.
Take the tire off and cut the offending spokes out. You can get individual spokes on E-bay and the like.rashad wrote:so one more question... do you think I will be ok with two loose spokes for now? They are opposite each other, so that is good i guess... It has held up fine so far.
you are the man.6 Riders wrote:You'd be buying a spoke for a 19" DID rear wheel, you can get an OEM spoke as well, same thing. Don't forget the nipple.
To be exact it's a 202 X 106D spoke, used on all KX 19" rear wheels since 1989. If you are buying OEM, it will be called "inner spoke", don't let that confuse you, all 36 spokes are the same size/length.
