Sgt.harper48 wrote:Put stock jetting back in all new lines after thoroughly cleaning tank and petcock as well as carb again. I just don't understand this stuff. I'm seriously either going to send it to the dealership or sell it I just don't know anymore.
I understand the discouragement but it's awefull easy to have patience from the dealer end when their billing out $60-$80 an hour.
That ground electrode color is really throwing me off ??? I'd double check the gas cap by attaching a hose and see if you can easily blow air threw it.
I'd also disconnect the fuel line from the carb and see if you can blow compressed air back up threw the petcock.
Or I guess you could just let the gas run out the hose and make sure your getting a good flow.
The plug center electrode looks fairly normal from what I can tell from the picture.
I'm sure you'll find it's a minor item thats causing this.
