E shock vs H shock - which mo bettererer ?
ohgood
Post by ohgood »
i have a E roller (suspension, wheels, frame) but no engine in it
and
i have a H super sexy beast-mode 220.
the spring on the H is grey, the spring on the E is blue. i wonder if either shock is considered better, or if either spring is more suited to tight trails (not motocross!) for an old fat guy (218 lbs) that ddoesn't care about going fast ?
thanks !
sarrant
Post by sarrant »
Very similar shocks, just with different reservoir orientation for their respective frame configurations. They're not interchangeable due to the resorvoir/frame relationship. I believe the silver spring is slightly stiffer.
ohgood
Re: E shock vs H shock - which mo bettererer ?
Post by ohgood »
sarrant wrote:Very similar shocks, just with different reservoir orientation for their respective frame configurations. They're not interchangeable due to the resorvoir/frame relationship. I believe the silver spring is slightly stiffer.
Thanks, I may change springs to see which I prefer
Has thanked: 5 times
the E is 4.6 and H is 5.0. You probably need 5.2 or so.
