Reed valve arrow?
Reed valve arrow?
Reed valve has an arrow on it, is the arrow supposed to tell me which way to put it in?
Reed valve arrow?
Not sure on arrow ,but the rounded tab (A) on the cage should be on the lower left side of the engine/bike.
- Tedh98
Re: Reed valve arrow?
Mine has an arrow on the metal piece that if you put it in one way it faces down and if you flip it up and put it in it will point up. It'll go in either way. Also my o rings are worn out on the head pipe could that prevent it from running? Oil was coming out pretty significantly
- KDXohio
Probably fouled the plug try a new plug
