Exhaust
Corey
Exhaust
Post by Corey »
Hey Folks,
Bought a top end gasket kit and they included the exhaust o-rings. Along with those they also included a copper ring that is the same O.D and I.D as the o-rings. Visited RMC and looked at the exhuast microfiche for a '96 KDX 200H. They have that listed as well. Question is does anybody use this for their exhaust and does it only work with the stock expansion pipe? I have an FMF Gnarly. Thanks.
KDXohio
Re: Exhaust
Post by KDXohio »
Yes pull out the old copper washer and put the new one inat least i still use it with my fmf
Corey
Re: Exhaust
Post by Corey »
Thanks for the reply KDXohio. I'll be installing it. Just curious, what's it's purpose? Never seen one used with my other bikes but this is my first KDX though.
Has thanked: 5 times
Re: Exhaust
Paper, scissors, rock. Like rock beats scissors, steel beats aluminum(badly), so it is a cushion between steel and aluminum.
KDXohio
Re: Exhaust
Post by KDXohio »
Great analogy!
offshoretitan
Exhaust
Post by offshoretitan »
That is a great analogy, Jason.
Corey, the Service Manual also recommends you re-install the gasket and o-rings with a little high temp grease, probably in part because of the movement / wear Jason refers to and it helps prevent exhuast leaks...
Service Manual exhaust reinstall.JPG (23 KiB) Viewed 1778 times
Corey
Re: Exhaust
Post by Corey »
Thanks for all the replies.
pumpguy
Exhaust
Post by pumpguy »
Usual arrangement is to use new O rings and high temp silicone sealant.
Copper is a common gasket material for engine cylinder heads. Nice thing about copper is you can anneal (soften) it by heating to a red heat. Quench in water or not is up to you; doesn't make any difference.
So, you can take the old copper gasket, clean it off, heat it red, and re-use it.
Corey
Re: Exhaust
Post by Corey »
Oh wow, ok I'll be definately doing that.
