KIPs actuator rod stripped?
pne
Post by pne »
Hi guys, I have been redoing the top end of my 96 kdx200 and carefully cleaned out all the kips components, lined everything up, and the subvalves/exhaust valve are all working smoothly when operated by the drum on the left side of the case under the round cover.
The problem is when I go to hook up the actuator and claw gear on the right side of the bike. It appears that whatever is clocking or timing the large rod coming from the lower crankcase is not functioning. I am able to spin the rod shaft, the one you are supposed to support while undoing the left handed nut, 360 degrees with no resistance or engagement.
Is this normal or is the mechanism in the case broken and requires pulling the case cover? Will opening the clutch cover permit access?
doctord23
Re: KIPs actuator rod stripped?
Post by doctord23 »
No not normal, the pin on the lower end of the shaft that slides into the actuator is broken off.
Pull off the inner clutch cover and you will probably find it.
Part number 13236-1260.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
pne
Post by pne »
thanks, I pulled the cover and the entire piece was missing, guess the previous owner broke it and chucked it.
doctord23
Post by doctord23 »
Should run much better with the kips working.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
diymirage
Post by diymirage »
yup, that will be like free power on the top end
-1997 KDX 220 project bike
s10gto
Post by s10gto »
pne wrote:thanks, I pulled the cover and the entire piece was missing, guess the previous owner broke it and chucked it.
Just make sure the pin is not in there. You don't want to find it the hard way.
pne
Post by pne »
I looked closely with a flashlight but it is gone and the 2 screws are out as well. I'm itching to break it in but I gotta wait on a $10 part to come in the mail now :butthead: I just bought this bike and have never ridden it before.
diymirage
Post by diymirage »
you can break it in without the kips actuator hooked up just fine
the kips just wont open and will be stuck in "low RPM mode"
