powervalve hit piston
argclh6670
Post by argclh6670 »
Hey guys, i pulled the topend on my kids bike 95 200 to replace after about 150 hrs. Noticed that at some point the PV made contact with piston. What causes this? Pv worn? Bike was running well still. Stock bore. Will add pics soon.
diymirage
Re: powervalve hit piston
Post by diymirage »
shouldn't be possible unless the barrel has been bored and an oversized piston installed (which you mentioned wasn't the case)
I cant think of any scenario that would cause this to happed
did you by chance measure the piston or did you go by the markings on it?
-1997 KDX 220 project bike
argclh6670
diymirage wrote:shouldn't be possible unless the barrel has been bored and an oversized piston installed (which you mentioned wasn't the case)
I measured it. Piston measures 66.
It doesnt make any sense to me either. Does or can the pv wear enough to seat further into its bore?
Jaguar
Country: Ecuador
Post by Jaguar »
on m y '89 200 it was impossible for the piston to hit the powervalve.
Did it damage the rings?
66 is stock bore, so can't see how the PV contacted the piston. Would have made a mess of things if it did. Pics?
argclh6670
bufftester wrote:66 is stock bore, so can't see how the PV contacted the piston. Would have made a mess of things if it did. Pics?
As you guys can see, it barely grazed it. bike was still running good and was holding 165 psi compression.
im just wondering why this happened. it also looks as if it had happened awhile ago due to the carbon buildup on contact point. im planning on putting a new topend and taking abit off the pv with a dremel.
