re: most spooge
BTW, FTR and all...currently 38-152-DEK/4-#7TV
Said before, but....I've been on both sides of that (more lean, more rich). Also said before but not in this thread...the more
rich the bike is setup, the
less it drips. It doesn't run better, but it drips less. The current jet-set works very well from the standpoint of performance.
GH:
FRP ported cylinder, no RH subport drum. My unported cylinder is sitting on the bench awaiting an aluminum slug.
Fuzzy:
Yeah. I thought that too...kind'a funny after Inda's first reponse regarding timing with race fuel/octane boosters. If you find out anything of note regarding advance/retard 2/4s...please let me know.
Jason:
Heck no. (Jason is referring to the fact that I found my RH subport drum banging around
inside my exhaust pipe awhile back.) Before I do that I'll put my spare OEM (unported) cylinder on..AND send my current cylinder to Langcourt to find out what they can do about all the pits in the plating USChrome (pics in the gallery) left behind. Ski has opined prior that he wonders about all the pits in my USChromed cylinder. Me, too!
Note that you can't see the mixture ring at all in the above pics. The color of the insulator tip doesn't mean anything when it comes to lean/rich air/fuel mixture. But...the flat of the
thread ring does. Now...
it's not pretty, either!
IC: Is there an operating rpm range where you feel the bike 'falls off' the power when the engine is not under load?
Not under load? No. Same
under load.
With the exception of being a PITA to start (due to the plug being so wide), the bike runs terrific! Starts hot easily, idles forever, throttle response ideal. I'm often one gear higher than I think I am. 'Gee...2nd gear should pull better than this!!'...and I'm in 3rd. With the KX forks on, this bike is a joy to ride..the best it's ever run!! That's a large part of why I don't care if the RH subport drum is gone or not!
I use SuperM. Generally 40:1. The above pics are 50:1 (close to it). That mix ratio suggested by Mr. Fredette.
Ski:
Interesting ...about the Mobil. Good to know stuff like that about different oils. Heck..I just bought about three gallons of SuperM. I'll be using it for awhile.
Believe it or not...a .028" plug and a 40:1 premix ratio is
worse drip-wise than the pics in this thread. That setup will leave actual
drips on the fender!
All of this is posted just for fun, mostly. What with many questions in years past regarding spoo=too rich, what plugs are supposed to look like and such...this whole scenario is just too curious.
Yeah. There is a bottom of things to get to about all this. Neat!
Thanks to all for the input. I appreciate it. Well...except for KayD doing another hijack attempt anyway....
