No Balls??
Surfnjmatt
No Balls??
Post by Surfnjmatt »
I have a 2000 kdx 220 and it just seems to have I balls in 1st and 2nd. It just winds out do fast.
I always read about the kdx putting you in your ass but I am a pretty novice rider and it just doesn't seem to have it.
In 3rd it will get some too end speed but where is my bottom?
The bike had a 49 renthal rear spriket when I bought it and I am 190lb without gear.
Could this be a symptom of bad reeds or low compression??
Surfnjmatt
Re: No Balls??
I am also getting a puddle of premix (not filter oil) in the air boot
Tedh98
Re: No Balls??
Post by Tedh98 »
You should check your reeds and compression. I would also make sure your KIPS is working and aligned correctly.
s10gto
Re: No Balls??
Post by s10gto »
I agree. If you got good compression pull the reeds out. Fuel oil in box is a good sign of the reeds curled open or broke. A 47T rear is stock so your should have nice bottom end with a 49T.
If all is ok like Tedh98 said check the KIPS timing. If someone did a top end some of the manuals are wrong and your KIPS maybe open all the time.
JasonK94Z
Re: No Balls??
Post by JasonK94Z »
You don't mention any mods to the bike. Pipe? Also, check you jetting. Not only did a pipe wake my 220 up, the jetting afterwards really got it going.
2002 KDX 220R
2003 KLR 650
KDX_Johnny
Re: No Balls??
Post by KDX_Johnny »
He has a full FMF... Looks like the woods though :cry:
Just a square trying to ram myself into that circular hole...
Has thanked: 5 times
Re: No Balls??
How long has it been since the last top end was done?
