i bought a nice 86 kdx200 pulled motor wiring pipe carb and swapped it on motor ran on the bike but was hard to start
now i only got it to start once on the trike frame
i inspected
spark good
timing plate /stator plate mark is lined up
flywheel looks ok???
compression 135psi after 10 kicks and needle stops
fuel yes if you give it throttle while kicking it flood easy
today kicking it it will try to start 2 bangs then nothing and it sounded like it backfired but the other day it did that in the expansion chamber
im in need of help here i have alot invested in this and alot of time into it as well
i bought a kx250 intake boot since it has side angle for carb but its too big can i use a 94 kdx200 boot on my 86 motor??
heres some picts
the first and last time it ran
