kips lubrication
dualscotty
kips lubrication
Post by dualscotty »
Hi there.what lubricates the kips system the premix oil or the gearbox oil.I'm sure its the premix oil.just want to be sure.thanx
JoKDX220r
Re: kips lubrication
Post by JoKDX220r »
premix
dualscotty
Thank you.
dualscotty
Also.when bike is running is the "rattle noise I hear " normal.
Tedh98
Post by Tedh98 »
Does the noise change when you pull in the clutch? If so, then probably just the normal noisey KIPS.
dualscotty
Pulling on the clutch doesn't make it go away. Changes the pitch a little.rev the bike up and it goes away.
dualscotty
So I am assuming that its normal for the kips to be a little noisy
Tedh98
Post by Tedh98 »
It is noisey. Running a full quart of tranny fluid seems to quiet it down a little.
dualscotty
If the premix lubricates the kips .how does the bottem end oil lubricate the kips.premix lubricate top part of kips and bottem end oil lubricate lower end of kips....thanks .
Has thanked: 5 times
dualscotty wrote:If the premix lubricates the kips .how does the bottem end oil lubricate the kips.premix lubricate top part of kips and bottem end oil lubricate lower end of kips....thanks .
Correct. Premix lubes the upper parts located in the cylinder. The KIPS governor and drive gear, located inside the right side engine cover, are lubed by the transmission oil.
dualscotty
Thank you.is the noise mainly from the upper or lower part of the kips or combination of both.thanks..I know I'm asking a lot of questions..I had surgery a month ago and I have another month of recovery here at home(boring!).so I have time on my hands.
dualscotty
I have 10w40 synthetic in the gear box.
Tedh98
Post by Tedh98 »
dualscotty wrote:I have 10w40 synthetic in the gear box.
Does that have friction modifiers in it?
I have been using ATF for years and like the price and how the clutch and transmission function.
dualscotty
Its valvoline synthetic like you would use in your car.is the atf you use the same as you would use in your cars automatic tranny
Tedh98
Post by Tedh98 »
Yes, it is ATF type f. I buy the cheap stuff at walmart
dualscotty
I am reading that a lot of people are running that.
