Does anyone know if a KLX 450 headlight/front fender can be made to fit an H series KDX?
Thanks,
Jeff
KLX 450 headlight/front fender on KDX???
- 6 Riders
Re: KLX 450 headlight/front fender on KDX???
Pretty sure the KLX head light uses rubber straps around the fork. If that is the case ( the 300 does use rubber straps) then it will fit. The front fenders between the KX, KLX and KDX use the same bolt pattern, or can be drilled to fit.
