Hey all,
New to the bike. It's a 220. Full FMF pipe and header. It seemed to be set up a little rich. But is any spooge leaking out the header at the engine normal? Any ideas if it's not? New gasket or something?
Thanks for the help!
T
Spooge out the header normal at all?
- diymirage
Re: Spooge out the header normal at all?
it should not come out the header
there are 3 parts to the seal, there is a copper gasket that sits in the cylinder, sandwiched between the head of the pipe and the cylinder itself
on the head of the pipe there are 2 O ring style gaskets
and the two springs keeping the pipe in place
I would check the springs, make sure they are still tight and replace if necessary
lots of people will also apply a thin coat of high temp RTV over the O rings to get a better seal
-1997 KDX 220 project bike
Thanks! That's what I thought. I will remove it and replace everything. I assume FMF sells the o rings etc?
T
T
Fmf sells the o rings. You may also find them at Rocky Mountain ATV.
2002 KDX 220R
2003 KLR 650
2003 KLR 650
Not to dredge this up again..... But can the spooge out the pipe be due to a leaking main seal ? Sorry if this is crazy......
T
T
