Crankshaft question ?
Ca94cr250
Post by Ca94cr250 »
Does anybody know what other year kdx 200 crankshafts are interchangable with the 1990 model ?
turtle
Re: Crankshaft question ?
Post by turtle »
I do not. But you should be able to go to cheapcycleparts.com to their parts listing and identify the part number. Then you can go back here http://www.cheapcycleparts.com/oemparts ... ycle/parts, plug the part number in, and see all the years and models it was used. Hopefully that helps.
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Ca94cr250
Post by Ca94cr250 »
Much appreciated !
They changed the nuts/bolts on the ends of the crankshaft sometime during the E series reign. You can use earlier or later type in any E bike but you might need the primary gear, nut, and the nut for the flywheel side as well, depending on which you have and which you are going to. I THINK the earlier model is inside thread for a bolt on the flywheel side, and later model is outside thread for a nut. Been a while since I looked into this, so make sure you do some research first! No clue on using an H series crank, but I considered it at one time, and I believe it would be possible with the right combination of primary gear, nuts, and bolts.
Ca94cr250
Post by Ca94cr250 »
Perfect thank you !
