need torque specs for the following bolts
hey cant buy a book for another 2 weeks need torque specs for clutch casing,clutch cover,nut for crankshaft-water pump primary,please any info will help
- ICRage42
Re: need torque specs for the following bolts
gabe you can get a hold of me today sometime just send me a text. I don't have my manual in the house its out in the garage but I can look those up for you later on in the day till you get your manual.
I am not certain, but most of the little bolts seem to be 78 INCH-pounds, if I remember correctly.
right engine cover bolts 78 inch/lbs
clutch cover bolts 78 in/lbs
kick pedal nut 36 foot/lbs
clutch spring bolts 78 in/lbs
clutch hub nut 65 ft/lbs
primary gear nut 58 ft/lbs
water pump impeller nut 87 in/lbs
water pump elbo bolts 78 in/lbs
water pump cover bolts 87 in/lbs
