Cheap spark plugs
Cheap spark plugs
Anyone know where you can get ngk spark plugs for less than 2 bucks? I know 2.50 isn't very expensive, but by time you buy 4 you are at around 10 dollars, which is still not too much but it each 10 dollar thing adds up. I was herring of people who bought a case for ten cents each, or even 99cents each. When doing the jetting guide instead of replacing the plugs can you just clean then with a brass brush and some brake cleaner?
Re: Cheap spark plugs
It's not like doing plug chops are ruining the plugs. After you use them to get your jetting right,they're still good. 4 plugs would be like 4 years of riding. I put a new plug in at the beginning of riding season and don't worry about it.
So I could just clean them since they aren't ruined. I would assume the coloring comes from some carbon or sponge buildup, so theres no reason it wouldn't wire brush off
- Has thanked: 5 times
Use a new plug for throttle chops, then you can use them for normal riding afterward. If you have your jetting spot on, you won't need a stack of plugs.
- TWMOODY
Cheap spark plugs
Not sure how any one here does plug chops but you can't read the ring on the porcelin very well with out cutting off the threads unless the jetting is so rich that your able to see the black ring down inside.
Plugs are cheap compared to a motor.
buy a plug reader or get to hacking
http://www.mfgsupply.com/br8es-box.html
this is the first hit from google for "box of br8es"
Under $2/ea
Under $2/ea
- TWMOODY
Jason wrote:buy a plug reader or get to hacking
I just use a cutting disc. Takes about 30 seconds . Never seen a plug reader ?
Always read my own .
left, 4-6 kicks, sporadically
right, half a kick every single time
I'll stock with the iridium until someone tells me they know better
http://www.jerrybickel.com/tools-and-eq ... c4090.htmlTWMOODY wrote:Jason wrote:buy a plug reader or get to hacking
http://www.ebay.com/sch/i.html?_kw=Magn ... ug+Reading
I just used a cheap handheld 3x/5x/10x handheld magnifier kit and a flash light.
Nope. It is real.
- adam728
What's a plug reading look like?
Ever take a gander at your piston wash?
Timing set vs stock?
Plug gap?
Condition of plug wire/cap and connection between coil/wire/cap/plug?
I never messed with iridium plugs in the KDX, just standard BR8ES. No problems with starting, 1 kick.
In my YZ I ran iridiums as it would foul a plug during warm up darn near every time. Once I worked out the jetting I ran standard BR8ES plugs in that too, changed the plug every time I changed the piston (every 50 hours or so).
Generally iridiums last longer, and deal with lower coil voltages a little better.
1 no idea, but requires choke when cold, warms quickly and status consistent throughout the day from morning to night.adam728 wrote:1What's your jetting?ohgood wrote:
2 What's a plug reading look like?
3 ever take a gander at your piston wash?
4Timing set vs stock?
5Plug gap?
6condition of plug wire/cap and connection between coil/wire/cap/plug?
2 wet/rich/lots?
3 not yet, when I have compression issues I will
4 no idea
5 .030"
6 excellent, fat blue spark
warm up is good, power is great, tractors up hills without bog revs like a banshee, wheelies in forth.
I'm familiar with 4 stroke, all this is new. I'm working on the "don't broke fix it" Principle for now, and believed the "replace stock piston asap" advice.
the closest I have is a buddy that observed the bike this weekend (years of two stroke affection and maintenance) who told me to enjoy it this summer and investigate everything when it turns cold in January. sound good to you? I'm all ears
