DOES THIS SOUND NORMAL
NewKDX
Post by NewKDX »
Does this sound normal
pumpguy
Post by pumpguy »
Mine doesn't sound like that, that's for sure. More history info would be helpful.
Re: DOES THIS SOUND NORMAL
Have you had the flywheel off yet? Sounds like a loose magnet or piece of magnet maybe, or possible the stator plate has come loose? Pull the flywheel and take a good look.
Postigo
Post by Postigo »
Is there something wrong with the bike? When you are playing with the flywheel there are a lot of parts moving too, like bearings, connecting rod, piston, clutch basket, water pump, tranny parts and KIPS actuator so at some level is normal to have noise by playing with the flywheel. If there is a problem please be more specific.
Has thanked: 5 times
bufftester wrote:Have you had the flywheel off yet? Sounds like a loose magnet or piece of magnet maybe, or possible the stator plate has come loose? Pull the flywheel and take a good look.
I agree.
NewKDX
Post by NewKDX »
Actually looks very good. Went back and relistened to your video, is the bike having issues? You may just be hearing the piston/rod/crank movement in the engine. Easy to pull the jug and make sure that the top end is in order, that would be my next move.
NewKDX
Post by NewKDX »
Well it didn't sound like this when I bought it. Do you think there is actually something wrong with the bike such as maybe piston rings, wrist pin, or crank bearings.
scheckaet
Post by scheckaet »
i don't know but i'm pretty sure mine does the same...
have u done anything to your bike before you noticed the sound?
NewKDX
Post by NewKDX »
No nothing at all just changed the spark plug.
It could just be noise from the clutch basket/crank/rod that is normal and you wouldn't hear it with the engine running. Is the bike running okay or have you been having issues?
NewKDX
Post by NewKDX »
Well I took the exhaust off to see the cylinder. Do everything sound normal? Does the cylinder need replaced? I have a video and image for you to look at
https://imageshack.com/i/ezokRXjEp
